Re: Hydraulic pump
C.J.
05-27-2000 14:40:25
I am not sure if this will help you, but I added a front pump to my D-17. The pump came off of a ford tractor. It had a four bolt hub that mounted perfect to my D-17. Ford offered three different length shafts for the pump, and the longest one worked on my D-17. You might see if a wd and a D-17 have the same crank pully or see if a D-17 pully will mount on a wd and go with fords linkage.
Anthony Donner
06-23-2000 10:28:33
 Re: Re: Hydraulic pump in reply to C.J., 05-27-2000 14:40:25
what model ford tractor did it come off of, i am trying to do this with my d-17 and canot find a hub to do this
