Company Logo (800) 853-2651 Shop Now
WD 45 pops out of 2nd gear
TennMatt1
11-02-2015 18:20:57
What do I need to do to solve the problem of my 45 popping out of 2nd gear???
cleddy
11-04-2015 12:54:35
 Re: WD 45 pops out of 2nd gear in reply to TennMatt1, 11-02-2015 18:20:57
We had a "C" that jumped out of 3rd gear. The quick fix was a rubber band cut out of an old inner tube wired on and when in 3rd we would just secure it in gear by hooking the rubber-band over the shifter lever. That worked all the years we used it. cleddy
Dieseltech
11-03-2015 17:44:50
Just fixed my cousin's WD-45 diesel for the same trouble. His cover off the transmission had a lot of fork travel when checked in each gear detent. Had at least 3/8 inch travel so I redrilled the cover for .410 ball size instead of 3/8 inch. Spot welded the rail detents and reground the other detent side so the transmission shift collars move farther as needed. It was a lot of work but all gears stay in now..
HFJ
11-03-2015 13:20:50
ok, let me try that again:
this thread might help
HFJ
11-03-2015 13:19:16
hi matt, was just reading another thread here about this:
http://forums.yesterdaystractors.com/viewtopic.php?t=1247861
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
