Company Logo Shop Now
B Model Engine
coxtavrn
10-29-2015 04:13:30
I'm restoring a 1954 B that has a locked up engine and have found a 1944 donor tractor with a running engine. Anyone know if the engines are interchangeable?
wilson ind
10-29-2015 16:53:15
 Re: B Model Engine in reply to coxtavrn, 10-29-2015 04:13:30
it will fit, however if restoring by definition must be original and ALL parts back to original specs.Maybe what you are doing is just a little refurbishing?
Dick L
10-29-2015 12:59:37
Not only are they interchangeable but after this many years chances are it has been upgraded to being the same horse power.
old
10-29-2015 09:19:38
Many times a locked up engine is not all that hard to free up. Plus if your doing a real restore you will be rebuilding that engine and replacing he sleeves in it and it is wet sleeve engine so easy to pop the sleeves out. To free it up pull the plugs out and fill it with ATF and let ti sit a week or two then try spinning it over using a 12 volt battery with short fast taps on the starter
Ted in NE-OH
10-29-2015 07:19:20
Yes it is interchangeably.
coxtavrn
10-29-2015 21:57:47
 Re: B Model Engine in reply to Ted in NE-OH, 10-29-2015 07:19:20
Thanks for the replies. Wilson Ind, you are correct. I'm not restoring, just refurbishing. I may rethink the engine swap though, even if they are interchangeable. I've tried other lubricants (WD40, PB blaster, etc) to loosen it up, but not ATF. I will give that a try.
BushogPapa
11-01-2015 16:12:16
 Re: B Model Engine in reply to coxtavrn, 10-29-2015 21:57:47
ATF + Lacquer Thinner penetrates even better....!!
But remember, ir IS Flammable..!!
Ron.
Today's Featured Article - ... [Read Article]
Latest Ad: 3 JD 6600 d combines 1 w 329 1 w 404 Turbo 1w 404 non Turbo believed to be good motors also 2 JD platforms and 643 ch posting for friend call for details. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
