bill mart
Going to be looking at a D-14. Anything bad that these tractors are noted for that I should look out for? Owners says the throttle lever is broken. Thanks, Bill
If it will run, check on how many gears it jumps out of, and if the ho low clutch stays in both ranges, and if the brakes will stop it when in neutral.
