Company Logo (800) 853-2651 Shop Now
WD transmission
micheal
10-11-2015 21:34:00
hello all, got my 50 wd running finally, now i find out reverse worked, but no forward gears. shift lever wont move trying to select 1 - 4. reverse ground initially but then went into reverse and i could zip around the yard backwards. what should i look for next? pull the two top covers and look at what is goinng on in there, torque tube cover and tranny cover and see what the heck is going on? what do you guys think? on the right track? tractor has been sitting for years awaiting me to have time to put it back together.
thanks very much. micheal
micheal
10-12-2015 09:15:32
 Re: WD transmission in reply to micheal, 10-11-2015 21:34:00
thanks guys, i checked for the water, didn't see any, will pull top covers off and see what is down there, hope just need a little prodding to get them to move again! don't want to pull too hard on the shift lever, don't want to snap that off. thanks all see if i can get some oil in all over the top shafts and see if that helps them move again! i think my hand clutch is stuck also, didn't seem to want to stop ground movement when i through it forward, but again i will take covers off and look in there from the top and see what i see.
thanks again.
micheal
BushogPapa
10-13-2015 10:27:21
 Re: WD transmission in reply to micheal, 10-12-2015 09:15:32
It is Normal for the Hand Clutch to move the tractor when cold or just started up..
When warmed up, it releases completely..it is just the cold oil dragging the parts..!
I always leave my Hand Clutch Released, to take the compressed load off the clutch spring..
Ron..
old
10-12-2015 10:03:24
If the oil level is up where it should be in all places you might just fire it up and let it run for say an hour or so and that may help move oil around and warm things up and free things up. Had one tractor that I could only get in one or two gears and the others freed up after a few hours of using it in those gears
old
10-12-2015 09:08:23
First thing I would check is to make sure it is not full of water. If you find water in it good chance the gears and all moving parts are rusted in place. I have an old 2N that you can not shift the gears due to rust all over the place in side the transmission. I would check to make sure it does not have a lot of water in it and maybe fill it up with ATF and let ti soak a week or so and see if things free up
grinder220
10-12-2015 08:55:36
I bought one that was the same way, been sitting in a shed for 20 years. Took the shift tower of and had to tap the rails loose with a hammer and brass drift as they were stuck and did the same with gears on the top shaft. Reverse is submerged in oil so it wasn't stuck. GOOD LUCK.
micheal
10-12-2015 20:28:27
 Re: WD transmission in reply to grinder220, 10-12-2015 08:55:36
well, not as bad as i thought. got everything open tonight. did have water in there. dang it. anyway, tranny had good thick coating of 80w on everything in there. top cover was the problem. boot had a hole in it that i didn't notice and must have been that way for a very long time. the lock ring and shield were just junk and lotta rust on the lever. got it out and got the forks and rods moving again. they were frozen, oil and working with them i have them moving now and they move like they should. new shield and lock ring and boot and knob and we should be good. i thought i might put hytran back in it, since it gets mighty cold up here sometimes, if i have to blow snow, maybe the hytran will let me shift the pto in gear a little sooner. 80w i could sit there for an hour trying to warm things up so i could shift the pto in gear! thanks all.
micheal
d beatty
10-14-2015 10:26:07
 Re: WD transmission in reply to micheal, 10-12-2015 20:28:27
I just changed the gear oil in trans. and rear end of my wd45 and used 80-90 gear oil with Lucas oil stabilizer. If you use Hy-Trans oil I would use Lucas hydraulic booster oil with the Hy-Trans.
BushogPapa
10-13-2015 10:34:43
Here is a Serious suggestion...
Remember to NEVER shift the PTO into gear BEFORE putting the Transmission in gear and the tractor must NOT be moving..
This is to keep you from abusing that PTO Gear and Gearbox...
They don't take a lot of abuse..
FWIW..!! Ron.
micheal
10-14-2015 10:00:51
 Re: WD transmission in reply to BushogPapa, 10-13-2015 10:34:43
good advice. thank you very much. got that pto box off last night. rear seal is junk but the rest of the box looks good. i wonder if i have the -45 pto box? how would i tell? i hear they are better (stronger) gears and all internals look good. shaft isn't too bad, kinda wollered out of shape, but not horribly bad. i wonder about the -45 pto box, because i have the -45 transmission clutch with the 3 plates in it, so someone must have upgraded some time ago. pto box is more red in color than orange also, that is what makes me wonder. thanks very much, get some parts in the mail shortly and i will put it back together and try it again!
thanks all.
micheal
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t ... [Read Article]
Latest Ad: WANTED looking for vintage Brake & Clutch riveting machine . Please provide pictures with details . Foot operated or ??? Please advise JJB [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
