Hello everyone,
I have 1950 Allis Chalmers CA that I received several years ago when my father passed away (he used it off and on, mostly for plowing in the winters). I'm not that savvy with tractors and don't use it often, but I have been trying to get it in better operational shape since I got it and have been learning as I go along.
After having the clutch professionally replaced (expen$ive) and some minor cleaning, repairs and new parts (draining tank/fresh gas, clean sediment bowl, air cleaner w/fresh oil, oil & filter change, new 6V battery, new points... and I just replaced the wires and spark plugs Champion J8C a few days ago) the tractor starts easily and runs but it lacks the really strong power necessary to push/pull/climb hilly areas.
I'd like to get the forum's advice on where to start and what to focus on in order to determine why it is not as strong as it should be.
[u:046244b730]A few things:[/u:046244b730]
a) After running the tractor for about 15-20 minutes in the woods trying to push some fallen logs with the front bucket I checked the newly installed spark plugs. [b:046244b730]Spark plugs #1 & #2 were much blacker and sootier than plugs #3 & #4.[/b:046244b730]
b) The hydraulic oil was low and I filled it prior to going to push the logs and the tractor did seem a bit stronger than previously.
c) I have never removed and cleaned the carburetor (didn't want to mess with it and screw things up).
d) The points & condenser were replaced a few years ago (so they are not new anymore)... I lightly cleaned the rotor and points which helped as far as starting.
e) I haven't done a compression test yet.
I know I still have a ways to go to get it in tip top shape, but any and all advice would be appreciated. Thanks!
