Company Logo Shop Now
Re: CA hand clutch
Nellie
11-14-1998 05:19:32
:My hand clutch went to pieces a few years ago. I got the parts from a salvage yard, this was the easy part. I got stuck like you are now. I took it to a shop who had the equipment to pull the old mess out. You need presses and pullers that most places don't have. It cost me about $80 for labor but I had no other way to get the tractor running again. sorry for the bad news.
I have to renew the final drive clutch on my '53 CA. The I&T manual says to "remove snap ring from shaft; then press or pull clutch from shaft". I can't see any snap ring! Is it hiding behind the bronze bushing? How do I get the bushing out? What sort of puller or press do I use to get it off the shaft? If anyone has seen how one of these come apart I would be really grateful for any advice.
Dan D.
11-18-1998 16:35:06
 Re: Re: CA hand clutch in reply to Nellie, 11-14-1998 05:19:32
: :My hand clutch went to pieces a few years ago. I got the parts from a salvage yard, this was the easy part. I got stuck like you are now. I took it to a shop who had the equipment to pull the old mess out. You need presses and pullers that most places don't have. It cost me about $80 for labor but I had no other way to get the tractor running again. sorry for the bad news.
: I have to renew the final drive clutch on my '53 CA. The I&T manual says to "remove snap ring from shaft; then press or pull clutch from shaft". I can't see any snap ring! Is it hiding behind the bronze bushing? How do I get the bushing out? What sort of puller or press do I use to get it off the shaft? If anyone has seen how one of these come apart I would be really grateful for any advice.
Actually, the statement about removing the snap ring is a misprint. Onece the whole final drive assembly is removed from the tractor, it can simply be lifted off the shaft. Of course it is probably rusted. In that case, use lots of penetrating oil and lift on the clutch while using a brass punch to pund on the axle shaft. The use of a brass punch will ensure you don't damage the shaft. I had my CA apart last year and put in some new parts.
Jerry
11-24-1998 15:14:40
 Re: Re: Re: CA hand clutch in reply to Dan D., 11-18-1998 16:35:06
: : :My hand clutch went to pieces a few years ago. I got the parts from a salvage yard, this was the easy part. I got stuck like you are now. I took it to a shop who had the equipment to pull the old mess out. You need presses and pullers that most places don't have. It cost me about $80 for labor but I had no other way to get the tractor running again. sorry for the bad news.
: : I have to renew the final drive clutch on my '53 CA. The I&T manual says to "remove snap ring from shaft; then press or pull clutch from shaft". I can't see any snap ring! Is it hiding behind the bronze bushing? How do I get the bushing out? What sort of puller or press do I use to get it off the shaft? If anyone has seen how one of these come apart I would be really grateful for any advice.
: Actually, the statement about removing the snap ring is a misprint. Onece the whole final drive assembly is removed from the tractor, it can simply be lifted off the shaft. Of course it is probably rusted. In that case, use lots of penetrating oil and lift on the clutch while using a brass punch to pund on the axle shaft. The use of a brass punch will ensure you don't damage the shaft. I had my CA apart last year and put in some new parts.
I soaked it for 2 weeks, put a puller on it and broke the spring cover! If I take the pinion shaft bearing retainer off can I then drive the pinion shaft out the wheel end of the housing and through the clutch too? How big a hammer can I use without wrecking something else?
Thanks for the help.
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: I have A narrow front end from 65 Massey and also a front guard for a 65 Massey call or e-mail for price. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
