Company Logo (800) 853-2651 Shop Now
Now I did it an other WD
blue water massey
07-15-2015 16:41:24
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
ok so I bought an other WD 1953 per the serial#
has a loader not sure of the make has a pretty beat up blade on it now and the drop bucket is still to get here last pic is of the loader tag what you can see of it
has a home made 3 point
new rear tires tubes and loaded last year
also came with a snow blower and a new set of tire chains
as new tires around here run in the $800 mark $700 delivered (about 200 miles) was not bad I figure
it does run and after draining the tank and fuel lines of crude n water it runs pretty good
going to have to clean up the carb as it's gummed up as well as I'm still getting chunks out the bottom drain
if you look you can see my 1950 WD in the background
also have a 1955 WD45 parts tractor
have the hood as well but I will need to replace the exaust gaskets so will wait to install it later
is the carb correct for this as it's more than twice the size of my other one and there isn,t one on the parts tractor
Bill(Wis)
07-16-2015 06:16:10
 Re: Now I did it an other WD in reply to blue water massey, 07-15-2015 16:41:24
That's a Marvel Schebler carburetor which late WDs and WD45s had. Most early WDs used Zenith carbs which were smaller in appearance. They're interchangeable.
Bob Bancroft
07-15-2015 17:41:44
Loader made for AC by Freeman.
Aaron SEIA
07-15-2015 16:56:32
Loader is an Allis. The CA 8 was made for a CA. The WD 9 was the WD version. Didn't know a CA loader would fit a WD.
AaronSEIA
blue water massey
07-15-2015 21:06:23
 Re: Now I did it an other WD in reply to Aaron SEIA, 07-15-2015 16:56:32
CA loader on a WD
why do I always find the oddballs
Butch(OH)
07-16-2015 04:26:17
 Re: Now I did it an other WD in reply to blue water massey, 07-15-2015 21:06:23
Not to worry, A-C 3 point and those rear rubbers are $$$$$ I see lots of potential
JMS/.MN
07-15-2015 16:52:31
WD came with the Zenith 161AX carb, or Marvel-Schebler TSX149..... WD45 with the Marvel-Schebler, which is what you pictured. The curved shifter/constant mesh transmission came out in late "52, at sn 127008. Battery ignition/distributor 1953 at sn 136318, last WD at 146606.
blue water massey
07-15-2015 21:28:03
 Re: Now I did it an other WD in reply to JMS/.MN, 07-15-2015 16:52:31
a Marvel-Schebler carb
it's more than twice as big as the Zenith on my other WD
thought it was a ford carb by looking at it no (tags left)
at least the box of odds n ends that came with it has carb gaskets & seats
blue water massey
07-15-2015 21:01:30
sn WD141814
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
