Company Logo Shop Now
AC-72 Combine set up
Bryans2020
06-09-2015 21:39:08
Can someone tell me the how to set the AC-72 up for wheat ?
What the Cylinder speed should be ? the gap or height for the cylinder?
How far open should each of the sieves be ? and how to set the air valve?
Is there a publication with all that stuff in it ? Bryan
fastfarmall
06-10-2015 06:23:48
 Re: AC-72 Combine set up in reply to Bryans2020, 06-09-2015 21:39:08
Owners manual, do u have luxury of one of them? The 72 has a open concave i think. Well is that winter wheat, or a Hard Red Spring wheat, If it's a easy threshing wheat. it's easier to set,The harder the wheat is too thresh the faster you want the cylinder to go, but no faster then necessary, because that cracks the wheat too. The front of the cylinder can be open 3/8 and have it almost tight in the rear of cylinder to help separate the grain right there. You want the wind to be set high enough to float the chaff and heads up and off the sieves.The top sieve can be 3/4 open, and the bottom sieve is the most important , maybe 1/4 to 3/8 open. The only thing you want to send back to the cylinder is unthreshed heads, and the bottom sieve controls that. These are for the normal open concave grated combine. The A and C cleaner for example is a solid concave. So it's a lot of trial and error,my dad bought a new A Gleaner combine in 1962,Talk about a honey of a Machine, and easy to work on, to boot!
fastfarmall
06-11-2015 08:49:03
 Re: AC-72 Combine set up in reply to fastfarmall, 06-10-2015 06:23:48
Maybe i should define easy threshing wheat, you take one head of wheat and smash it in the palm of your other hand and rub it 3-4 times, Blow in the palm of your hand to get rid of the chaff. Then look at the base of the head to see if all the kernel's are out of there, if there's 3-4 kernel's left in the base. That is hard threshing wheat.Those kernels are usually smaller then the other's in the middle of the head, therefore harder to get out. Good Luck.
Bryans2020
06-11-2015 18:38:31
 Re: AC-72 Combine set up in reply to fastfarmall, 06-11-2015 08:49:03
Thank You !
I was finally able to locate the OPERATORS INSTRUCTIONS MANUAL. I went down the set up list for wheat and it was just like you said, most of the settings were already correct, only the sieves needed adjusting. There are only 4 cylinder bars but I think I'll be o.k.
Thanks again Bryan
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
Latest Ad: 3pt hitch for ford 3930 [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
