Company Logo Shop Now
What year was this one made?
wellmax99
05-30-2015 13:47:01
great looking old tractor with some updates. third party image
NEKS
06-03-2015 20:13:22
 Re: What year was this one made? in reply to wellmax99, 05-30-2015 13:47:01
If the front wheel assist was driven by the PTO, it could of taken two trannys to get the speed needed to match the front end.
fastfarmall
06-02-2015 08:48:50
Didn't Bush Hog Co, make hyd assist for every thing and anything years ago ?
willie in mn
05-31-2015 17:59:26
Have looked over the pic a few times. Would like to spend an hour or two up close to it.
This is what I get from the pic, have been wrong many times before & maybe wrong again.
1-just forward of steering support looks like WD style straight shifter.
2-forward of that shifter looks like handle for a hyd valve, with extension rod pointing rearward withing driver's reach.
3-below gas tank, rearward of headlight looks like WC style shift tower, with the handle bending around to the taller knob. Maybe 2 transmissions.
4-no opinion on the hyd tank on frame rail.
5-in the shadow just forward of the hyd tank, below the headlight, looks like round belt pully block off cup.
6-below the frame rail, is that a pto shaft? very easy to reverse the pto box below trans to point shaft forward.
7-looks like Delco mag to dist converter, dist is pointing upward. not sure, but think WD45 came with dist from factory. that would have cap pointing rearward, similar to mag.
Now that I have everybody confused, will say bye-bye.
Willie
gtractorfan
05-30-2015 16:07:41
Would have been great on a cornpicker during a muddy fall.
d beatty
05-30-2015 14:06:17
It looks like a WD 45 and the 45s were built between 53 and 57. As far as I know Allis Chalmers didn't build a WD 45 with 4 wheel drive. Looks like something somebody added to tractorin latter years.
Ralphwd45
05-30-2015 13:58:07
That looks like a WD45, with front wheel assist! I have never seen one before!
kent@junction
05-30-2015 17:14:59
 Re: What year was this one made? in reply to Ralphwd45, 05-30-2015 13:58:07
hydro driven? bet that makes her a real go getter looks like they may have used the belt pulley to power it. More details?
wellmax99
05-30-2015 17:33:48
 Re: What year was this one made? in reply to kent@junction, 05-30-2015 17:14:59
I just saw the picture on another site, thought you guys might like to see it.
had not noticed or thought about how they powered the front wheel assist.
I see that box on the side where the belt pulley would normally have been.
you think that is some type hydraulic pump driving the front wheels?
would almost have to be, as that tractor would not have had a front pto to operate the front wheels.
Today's Featured Article - ... [Read Article]
Latest Ad: 3 JD 6600 d combines 1 w 329 1 w 404 Turbo 1w 404 non Turbo believed to be good motors also 2 JD platforms and 643 ch posting for friend call for details. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
