Company Logo Shop Now
position of magneto timing
earlyduck
04-29-2015 11:06:02
believe I have a 1950 Allis Chalmers b model lost position of timing,plastic piece that was on back of gear with A and C on it fell apart need picture of gear with A and C on it relative to flat edge so we get timing marks back any help would be appreciated thank you
earlyduck
04-30-2015 20:16:11
 Re: position of magneto timing in reply to earlyduck, 04-29-2015 11:06:02
thnks for all the info but believe I have found the problem, the gear that should have a and c on it fits on a shaft with a bearing that fits in the end cap. the bearing is spinning inside cap and moves back and forth believe it's being held to far away from end cap cover not allowing spark. try to check it this weekend and post thanks again for all the help
tractorguy2
04-30-2015 21:42:35
 Re: position of magneto timing in reply to earlyduck, 04-30-2015 20:16:11
Bushing loose in the cap is a common problem. It can be fixed with jbweld or loctite.
tractorguy2
04-29-2015 21:41:57
I have timed several FM type J mags with marks.
Position the rotor so it is pointing just under the timing lug. Turn the small gear so the filed tooth is pointing up. Then put the cap on.
old
04-29-2015 14:50:31
Send me an e-mail and what mag you have and I will in turn send you by way of e-mail an manual for your mag. I have manual;s for the 2 common mags used on that tractor
stu (ON)
04-29-2015 13:03:08
http://rodnh.byethost12.com/acb/magtiming/magtiming.htm
http://dueyschutter.freeservers.com/photo6.html
earlyduck
04-29-2015 17:46:55
 Re: position of magneto timing in reply to stu (ON), 04-29-2015 13:03:08
thanks stu ill try this tomorrow night and let u know
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
Latest Ad: 3 point drag arm for 420 HD crawler right side [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
