Company Logo (800) 853-2651 Shop Now
5040 Electrical problem
keith427
02-02-2015 06:32:37
I have a 5040 that has a relay or voltage regulator that is smoking. It is on the firewall. If I disconnect the brown ground wire on the mount it quits smoking but the voltage jumps to 16v at the battery. I am assuming it is bad but not sure and if so where to get a new one.[img][/img] third party image
Traditional Farmer
02-05-2015 19:05:57
 Re: 5040 Electrical problem in reply to keith427, 02-02-2015 06:32:37
I run a couple 5040 AC tractors,I went with 1 wire
Delco alternators.
keith427
02-10-2015 07:16:45
 Re: 5040 Electrical problem in reply to Traditional Farmer, 02-05-2015 19:05:57
I purchased a new voltage regulator and it also starting smoking. I checked voltage at the battery and it was 15.9 volts. Apprently something is wrong with my alternator. How did you hook up the single wire Delco?
vapet
02-03-2015 14:41:37
The parts store here has the regulator.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
