Re: AC C starter turns slow
Phil Auten (TX)
04-27-2000 16:53:28
DJ,
Congrats on getting the starter out. Try taking it apart and cleaning it up. Be careful with the brushes, those wires can get broken easily. Clean the bushings in either end and lube them with just a touch of moly grease like car suspensions use. Brushes shouldn't be more than $10 and are simple to replace. This might do it unless the commutator is obviously not smooth. If that's the case, call around to several auto electric shops for estimates to repair it. It'll probably cost at least $40 but shouldn't be more than $75-$80 max.
Good luck,
Phil
DJ
04-27-2000 18:48:16
 Re: Re: AC C starter turns slow in reply to Phil Auten (TX), 04-27-2000 16:53:28
thanks for the advice. I will try it out. I have a book that i think shows the internals of a starter. I know what the brushes and commutator look like. question though, where would I go to purchase new brushes, and are they all the same, or do I ask for something special? Thanks again, Phil you have been a great help
Phil Auten (TX)
04-30-2000 14:47:01
 Re: Re: Re: AC C starter turns slow in reply to DJ, 04-27-2000 18:48:16
DJ,
Good question. Any auto electric shop should be able to get the brushes by using the Delco or Prestolite number from the generator tag. Most likely, NAPA will be able to do this too. All will depend on the person you are dealing with at the counter. Take the starter with you so they can see the tag.
Phil
