Company Logo Shop Now
Difference between Fairbanks Morse Magneto's
salfonsi
11-13-2014 18:11:23
What is the difference between a Fairbanks Morse Type FM-j4b3 and a Type FMJ - 4b3a? Allis Chalmers C - 1949
Jerry Coulter
11-16-2014 18:08:38
 Re: Difference between Fairbanks Morse Magneto's in reply to salfonsi, 11-13-2014 18:11:23
The FMJ4b3 generally fits the B,C,WC and WD. The FMj4b3a fits the late WC which has the kill rod next to the choke rod. The model FM magneto has a 1 piece cap whereas the FMJ has the 2 piece cap.
salfonsi
11-16-2014 18:13:22
 Re: Difference between Fairbanks Morse Magneto's in reply to Jerry Coulter, 11-16-2014 18:08:38
thank you...
tractorguy2
11-14-2014 07:16:48
I think the j4b3A has a slightly different lag angle. Most have the lag angle marked on the paw plate.
some mags had the "kill" terminal on the left side for the lever kill and some had the "kill" terminal on the right side for the push button. Either they are still a type FMj3b4.
There is a later version type FMx3b4
Mr. T. Minnesota
11-14-2014 04:41:56
 Re: Difference between Fairbanks Morse Magneto's in reply to campcy, 11-13-2014 18:11:23
S,
Check with Standard Magneto in Chicago, Ill. You should be able to find them on the internet. They should be able to answer your mag questions. HTH
Mr. T. Minnesota
wilson ind
11-28-2014 16:03:11
 Re: Difference between Fairbanks Morse Magneto's in reply to Mr. T. Minnesota, 11-14-2014 04:41:56
I have dealt with them, good service and willing to talk with you,
salfonsi
11-13-2014 19:13:41
so there is no difference between type FM and type FMJ?
steve(ill)
11-14-2014 05:16:30
 Re: Difference between Fairbanks Morse Magneto's in reply to salfonsi, 11-13-2014 19:13:41
FM is a manufacturer - Fairbanks Morris... J is the model.. FM-J or FMJ are the same thing.
steve(ill)
11-14-2014 05:22:55
 Re: Difference between Fairbanks Morse Magneto's in reply to steve(ill), 11-14-2014 05:16:30
http://www.oldengine.org/members/diesel/FairbanksMag/MagFMType.htm
FM-J is the model .......... look at bottom of page for specific options -- ( 3 = Allis ) The 4J means it is for a 4 cylinder... could be 2 or 1 models also.
steve(ill)
11-13-2014 19:09:10
the "3" means it is for Allis. The "B" means it is a flange mounted mag.. I have never seen an "A" on the end.
tractorguy2
11-28-2014 16:39:08
 Re: Difference between Fairbanks Morse Magneto's in reply to steve(ill), 11-13-2014 19:09:10
I have seen one FM J4B3A magneto.
I'm pretty sure when I took it a part the paw plate was stamped 35% and not 30. Someone else could have changed it.
Could also be that the kill terminal is on the left side. I have seen 4B3 with kill terminal on the left and on the right. The styled WC I think used the mag with the kill on the left side.
A J4B3 and a J4B3A are close enough they will interchange.
Latest Ad: 1968 John Deere 3020 orchard diesel, needs full restoration. Asking 8500 or best offer. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
