Company Logo (800) 853-2651 Shop Now
AC wire diagram
Rick Cook
11-05-2014 06:25:57
I just bought a 42 AC C with 6v system none of the wires was hooked up except the magneto ground which was defective. The battery cables was also missing, The book that I have doesn't show wiring, does anyone have a wiring diagram? I'm also not sure if the wires are run through the tractor correctly.
steve(ill)
11-07-2014 17:55:25
 Re: AC wire diagram in reply to Rick Cook, 11-05-2014 06:25:57
third party image
Rick Cook
11-10-2014 11:35:15
 Re: AC wire diagram in reply to steve(ill), 11-07-2014 17:55:25
Exactly what I needed. Since the tractor is 100 miles away took me time to get to it only to find out that the old harness was shorted out and broken. So I ran new wires. Thank you all.
JMS/.MN
11-05-2014 07:23:16
google Allis Chalmers model C wiring diagram. Diagrams are in the operator manual, not usually in the service manual. The C was positive ground, so should have one heavy (neg) cable to starter terminal. Power to system also comes off of that terminal with a smaller wire.
Pg 4 here has an IB diagram, same as C, but for voltage regulator system.
Pg 3 here has original diagram under "WD45 generator".
Rick Cook
11-05-2014 10:59:35
 Re: AC wire diagram in reply to JMS/.MN, 11-05-2014 07:23:16
I've googled it to death. It seems that a harness has 5 wires to it. One seems to be for the lights, goes back to the switch. and two to the generator but I don't know where they would go to. One would be the ground for grounding out the Mag, but from there I don't know. But the links in the post don't show up.
chalmersbob(pa)
11-05-2014 18:34:29
 Re: AC wire diagram in reply to Rick Cook, 11-05-2014 10:59:35
the 2 from the genny are the "field wire and goes to the resistor on the 3 position light switch. the other one is the "battery wire" and goes to the amp meter. thes would be 14 gauge wire. You would also heve a 10 gauge wire from the starter terminal to the amp meter. LOL Bob
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
