Company Logo Shop Now
AC 180. Reverse gear put back on??
reggie1086
10-20-2014 13:04:00
Looking at another tractor purchase- a A/C 180.. does this sound like anything typical?
The ad Reads-
180 Allis diesel good running engine 800hrs on overhaul needs reverse gear put back in the gear shafts worked back and the gear fell off newer front tires rears hold air dual hydraulics..
Thanks! Reggie
reggie1086
10-20-2014 13:20:04
 Re: AC 180. Reverse gear put back on?? in reply to reggie1086, 10-20-2014 13:04:00
How is the gear or shaft retained in position then bob?
Bob Bancroft
10-20-2014 13:39:20
 Re: AC 180. Reverse gear put back on?? in reply to reggie1086, 10-20-2014 13:20:04
Can't remember if it's a setscrew or tab with a capscrew in it that keeps the shaft from sliding in the housing. Gear slides freely on the shaft- engaged by the reverse fork when you put the trans. cover on.
Bob Bancroft
10-20-2014 13:15:25
Doesn't sound typical. But these things are a lot older than they were when I worked on them! I think it was a 7000(same design transmission) I worked on once that only needed the reverse idler. I rigged up a miniature cylinder on a porta-power to push the shaft back. As I recall you can access the back side by removing the PTO housing.
Today's Featured Article - ... [Read Article]
Latest Ad: 3 JD 6600 d combines 1 w 329 1 w 404 Turbo 1w 404 non Turbo believed to be good motors also 2 JD platforms and 643 ch posting for friend call for details. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
