Re: welding
Peter
11-10-1998 14:08:57
: Need some tips on vertical arc welding, or some links with some informative reading on arc welding.
Should of posted this at JD because all their stuff needs repairing
Cliff
11-14-1998 19:59:57
 Re: Re: welding in reply to Peter, 11-10-1998 14:08:57
: : : Need some tips on vertical arc welding, or some links with some informative reading on arc welding.
: Should of posted this at JD because all their stuff needs repairing
: the best way to weld it, get someone who knows how to weld! Or spend a lot of time practicing!!!!
greg reuter
11-21-1998 19:26:16
 Re: Re: Re: welding in reply to Cliff, 11-14-1998 19:59:57
Reorient for down-hand if you can.
Otherwise, if you have access to a wire-feed
or mig welder with adequate capacity, use it.
It will make gravity less of a problem.
: : : : : Need some tips on vertical arc welding, or some links with some informative reading on arc welding.
: : Should of posted this at JD because all their stuff needs repairing
: : the best way to weld it, get someone who knows how to weld! Or spend a lot of time practicing!!!!
