Company Logo (800) 853-2651 Shop Now
Engine indentifiers
Dodgeit
09-22-2014 02:35:20
I have a WD that I just bought to use as a pulling tractor. She has some good power so I was wondering how I could identify which block was in it.
Thanks
ACEd
09-22-2014 05:02:50
 Re: Engine indentifiers in reply to Dodgeit, 09-22-2014 02:35:20
As to blocks, you could have anything from a WC to WD to WD45 to D17 etc. But that tells you nothing of what is currently inside - pistons, crank, compression ratio, etc.
The biggest difference in blocks would be the early WC and WD blocks have a removable plate bolted to right side of block. The WD45 and D17 blocks do not have this plate.
If you really want to know how block started life, look for s/n steel stamped into left side of block behind carb. You may have to scrape off grease or paint but is should be in small rectangular flat spot.
Look for both prefix (W, WD, 45-, 17- etc) as well as suffix (K, G, HA, KA GA, PA, K, G, GH, etc) - A is aluminum pistons, K is distillate (low CR), G is gas, HA is early High altitude (higher CR). CR increased over years - PA is later WD gas with higher CR than GA. WD45 increased displacement and went back to G, K, etc - GH was LP on WD45 I think. Dont have the D17 suffixes off hand, but they would have been higher CR still.
Dodgeit
09-22-2014 09:12:58
 Re: Engine indentifiers in reply to ACEd, 09-22-2014 05:02:50
Thanks for that I'm wondering if it may not be a Combine engine
ACEd
09-22-2014 09:30:30
 Re: Engine indentifiers in reply to Dodgeit, 09-22-2014 09:12:58
Not sure which AC combines would have used any engines other than those described above that would be a drop in. I have seen a 6 cyl gas combine engine in a WD45 chassis - but I think it was a replacement for WD45 Diesel 6 cyl.
Look for ID s/n behind carb - thats best starting point.
Dodgeit
09-22-2014 10:35:11
 Re: Engine indentifiers in reply to ACEd, 09-22-2014 09:30:30
OK thanks for the information
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t ... [Read Article]
Latest Ad: WANTED looking for vintage Brake & Clutch riveting machine . Please provide pictures with details . Foot operated or ??? Please advise JJB [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
