Company Logo (800) 853-2651 Shop Now
Update on 49 WD
Farmallb
09-20-2014 11:31:36
Got it to running pretty good. Where the manifold is leaking, the outside port on the R side looking at it, I have either a valve or lifter sticking. Im going to see if I can find some material to make a washer to fit in between the manifold inserts on that port to close it off, but don't know how to deal with the other problem. Other than take it to a mechanic. Ive put atf in the cyl ports, and down the manifold. Let it set a week each time. If its helped, it hasn't helped that port, #4
BushogPapa
09-23-2014 19:09:14
 Re: Update on 49 WD in reply to Farmallb, 09-20-2014 11:31:36
For sticking valves, have the engine running above idle, take the small plug out of the Intake runner and shove a full pump-type oilcan in that hole and pump in the (used engine oil) as fast as the engine will take without killing it.
Problem solved..(on an AC)..
Ron..
(PS..expect some SMOKE!!).
Farmallb
09-23-2014 20:38:49
 Re: Update on 49 WD in reply to BushogPapa, 09-23-2014 19:09:14
What is, Where is the intake runner and plug??
BushogPapa
09-24-2014 20:58:42
 Re: Update on 49 WD in reply to Farmallb, 09-23-2014 20:38:49
There should be a small 4-sided plug in the intake manifold between the carburetor and the upper part of the intake in one runner.
That port was for hooking a Vacuum line to, to power Milking Machines )!!..
If your is original, it should have it.
Ron.
jr1983
09-21-2014 10:20:56
pull the valve cover and see which one sticking. Most of the time you can lightly tap them with a hammer and have them break loose.I would advise a dead blow.
Farmallb
09-21-2014 10:57:28
 Re: Update on 49 WD in reply to jr1983, 09-21-2014 10:20:56
I pulled the valve cover, and reset the tappits. Everything on top was moving as expected.
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
