Re: B Mower Attachment
D13
04-24-2000 09:10:11
Next time it's taken of the tractor only lower it enough to get it free. Loosen the front, jack it up slightly, block it up, then pull all the bolts. The left front support at the torque tube should swivel down out of the way, so the only problem is clearing the drawbar. Lift the mower up slightly in the rear, block it up, cut the wheels to the right, and back the tractor off the mower. Reverse to install. Mine mounted to the top of the drawbar and shimmed up with 3 washers per side to get the right belt tension. Your drawbar is too loose if it's loose at all - try repositioning it (there are 3 sets of holes in the drawbar) until it looks to be in the right position, then use large washers to shim for belt tension. The drawbar shuld not have significant slop in it when it is installed correctly - you may need to redo the bolts or clamp plate pins. Belt should not be real tight as this will load pulley drive and fail it. Gools luck and enjoy - these are sweet machines.
David
04-24-2000 09:40:03
 Re: Re: B Mower Attachment in reply to D13, 04-24-2000 09:10:11
Thanks for the info. I knew there had to be an easier way!!
