Buddy
Allis Chalmers G worth anything?
I won this tractor on a sealed bid.
Tractor has been sitting many years but, the engine is free and it does have the cast counter weight mounted on the front.
Also have the cultivators on it. No hydraulics.
Needs tires, they hold air , dry rotted pretty bad.
Where are you located and do you have pictures? They can be worth $500 to several thousand dollars, a picture would help. The weight and cultivator is a plus but the tires and no hydraulics is a minus. Location means as lot as far as hauling.
Yes they can be worth some and by far more then what it would be if scrapped out. That is one tractor I have always wanted because they where made in the same town as I was born in
