What do I have? thought it was a wd-45 I was wrong
I traded for this yesterday thinking it was a WD or WD-45 I think it is a D-17? then the other question is after I drove it about 6 miles on my way home it started smoking bluesih black smoke and the head casket seems to be leaking between the head and the block down the side where the exhaust is so I am guessing blown gasket causing oil to get into the cylinders as well? Is it that simple or do I have bigger issues? When you first run it it looks good then as it warms up it leaks and smokes. is it worse then a bad gasket?
Thanks
Chad
Do you get on from the back or the left side ahead of the tire? Search the tractor id pictures or the web for pictures of the 2 and you'll know pretty quick. You can e-mail the picture to me and I can try to get it up for you also. aaron_cummings(at)hotmail.com
AaronSEIA
here are the pics I compared it side by side with our know wd-45 and there is just some odd differences. the engine number is the same but the seat is different and the rear end is different not much but it is.
It"s a WD45, or at least a late 1952 WD, cuz of the curved shift lever. Check the serial number- it is stamped on the differential, left side. What you show are casting numbers.
Ok I went out and looked harder on both of the tractors they are both 1956's the old one we already had was wd 204114 and the one in the pictures is 209834. I see why the rears look different there is a mounting plate adapter across the rear deck that mounts the different seat.
Now I just have to hope that the head gasket is the problem and nothing else.
thanks guys
