7020 axel seal
Anonymous-0
axel seal is leaking pretty bad on the 7020. left side. can a new seal be installed just by removing rear hub and pull old seal out? or does axel housing need to be removed and install from the inside? thanks for any help.
Pretty sure the seal can be replaced from the out side, if you have the right tools. A seal screw on a slide hammer should do it. Once the tire is off you would want to check for any lateral movement in the axle indicating the bearings bearings need to be adjusted. That would require removing the whole unit.
