Company Logo (800) 853-2651 Shop Now
Allis C / Allis CA transmissions
andyin ct
04-30-2014 02:00:32
Can I swap a 4 speed from a CA into a C? Thanks
Dakota Dave
05-03-2014 20:00:44
 Re: Allis C / Allis CA transmissions in reply to andyin ct, 04-30-2014 02:00:32
The hydraulic pump on a CA is a high pressure system the henderson loader was designed to operate on the Charlynn Combo pump. It is a low pressure system. its also fairly low flow so you will have average operating speed. but you can overpressure the loader rams.I use a Allischalmers modle 100 on my CA the loader works fast enough for mee the cylinders are about the size of henderson loader rams but much sturdier.
JMS/.MN
04-30-2014 07:33:49
Internals? no.
andyin ct
04-30-2014 07:55:22
 Re: Allis C / Allis CA transmissions in reply to JMS/.MN, 04-30-2014 07:33:49
No - complete transmissions.
Dick L
04-30-2014 08:56:57
 Re: Allis C / Allis CA transmissions in reply to andyin ct, 04-30-2014 07:55:22
Sure you can. I have a C with a CA transmission out back in my scrap yard. I plan using that transmission in one of my B's.
steve(ill)
04-30-2014 15:53:33
 Re: Allis C / Allis CA transmissions in reply to Dick L, 04-30-2014 08:56:57
IF you retain a hydraulic system, the pump/ valve must be off the CA.. a B/C pump would not fit.
bg/mo
04-30-2014 19:16:12
 Re: Allis C / Allis CA transmissions in reply to steve(ill), 04-30-2014 15:53:33
the whole pto hyd set up must be for a ca? or would complete pto unit from b/c work??
Dick L
04-30-2014 19:33:03
 Re: Allis C / Allis CA transmissions in reply to bg/mo, 04-30-2014 19:16:12
If you want hydraulics it all has to be from a CA including the pto/belt pully housing. Then if you want hydraulics you will not use the (normal) B or C bench seat.
Sam (Wi)
04-30-2014 19:57:39
 Re: Allis C / Allis CA transmissions in reply to Dick L, 04-30-2014 19:33:03
Would the CA hydraulics be good enough for a Henderson loader?
Dick L
05-01-2014 04:13:31
 Re: Allis C / Allis CA transmissions in reply to Sam (Wi), 04-30-2014 19:57:39
The hydraulic pump is basically the same pump as the WC pump. I bought a non running CA with a Henderson loader mounted on it and it was hooked into the CA hydraulics. I took the loader off to repair the tractor but the loader still sets out in the scrap area and was never remounted to the tractor. I don't know how fast the loader lifted.
steve(ill)
05-01-2014 15:21:36
 Re: Allis C / Allis CA transmissions in reply to Dick L, 05-01-2014 04:13:31
some of the CA rear lifts used two 1-1/2 inch cylinders... I would guess the front boom cylinders are comparable diameter and would be adequate for speed... Will not be too fast, but should work.
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t ... [Read Article]
Latest Ad: WANTED looking for vintage Brake & Clutch riveting machine . Please provide pictures with details . Foot operated or ??? Please advise JJB [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
