Company Logo Shop Now
WD NARROW FRT
DWCYour Handle
03-22-2014 05:39:51
HAVE A WC FT END ON A WD45 FOR PULLING AND THE FRT END IS PRETTY LOOSE GOING DOWN THE ROAD. HAVE PUT NEW PINS IN AND TIGHTENED GEAR UP TOP. SEEMS TO BE IN BOTTOM OF PEDESTAL. SOOO BEFORE I START TEARING APERT WHAT TO LOOK FOR OR SHORTCUTS.DWC
Aaron SEIA
03-22-2014 08:38:56
 Re: WD NARROW FRT in reply to DWCYour Handle, 03-22-2014 05:39:51
Could also be the setscrew and key between the wheels on the spindle casting. Straight key and straight keyway make for wobbly steering.
AaronSEIA
Lonnie Smith
03-22-2014 05:53:47
Probably the bottom bearing is shot. If you jack up the tractor so the front is hanging loose you should be able to see if that is where the play is.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
