Company Logo Shop Now
replace oil, D17
ohiojim
02-22-2014 06:07:38
the job is complete, now to replace the oil, it appears to have had the 80 wt. that the manual calls for and is just my opinion, i have some 80-140, should i use it or can i go with the other option stated in the manual of SAE 20/20,..any problems with the switch..
Brian Jasper co. Ia
02-23-2014 18:36:47
 Re: replace oil, D17 in reply to ohiojim, 02-22-2014 06:07:38
On the other forum, there's a couple guys who worked on these when they were new. They will tell you to put universal trans/hyd fluid in the trans, hand clutch, and hydraulics. Put the 80-140 in the final drives.
ohiojim
02-23-2014 04:44:30
it was a roll pin in the PTO shift lever, you can see it through the plate at the power director lever but not enough room to get the pieces out of the old one and put the new one in, $2.00 in parts and 4 hrs. to put them in
Bob Bancroft
02-23-2014 06:39:20
 Re: replace oil, D17 in reply to ohiojim, 02-23-2014 04:44:30
OK. I can't remember who was doing what on here. Too bad. I was hoping someone might come up with some special little tool to press the bugger out/in. The power director clutch works better with the lighter oil. They eventually put hyd/trans oil in everything on those tractors (except the final drives)
Bob Bancroft
02-22-2014 15:33:27
What was wrong/what did you do to it? Which compartment are you talking about?
maxwell99
02-22-2014 14:28:54
I would use the oil weight and type the manual calls for:
oil is cheaper than paying a repairman and buying new parts again.
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
Latest Ad: 3 point drag arm for 420 HD crawler right side [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
