Re: Advice needed on buying D17
Brian
04-16-2000 10:30:57
There is little comparison from series 3 to series 4 hydraulics. Untill series 4, all A-C tractors with the traction booster system had a low volume high pressure system with a max pressure of 3500 psi. If you wanted to use other hydraulic equipment, care had to be taken that you didn't over pressure the system, blow seals and such. A-C fixed all this when they put a system in the 4 that ran at the same pressures as most other brands were using. Now they had a tractor that had a system that would run a loader fast. For a working machine, the series 4 is the best. Otherwise, they are the same basic tractor. Hope this helps, Brian.
