wheel bearing seal
dahlin
Replacing the wheel bearings on the Allis B. I was wondering if the felt seal should be greased or oiled or put in dry? The book does not say.
What you DON'T want is that felt taking up moisture. I think I would soak it with oil, then let the excess drain off before assembly. Then be generous with grease.
