Company Logo (800) 853-2651 Shop Now
Gleaner F fan and sieve settings
4020 electrician
10-27-2013 17:49:19
I have the Sieve set at 1/2 inch and bottom closed fan all the way . I feel I should not be running fan full bore. I am still getting hulls in the bin. What is the best way to check if I am blowing seed out the back besides looking on the ground, cutter bar shattering can be deceiving . Running 44 tooth sprocket and running it slow still getting some splits. Is this normal or should I run my 52 tooth? My book I have is very delicate appears to have took on moisture some time in its life. Any help would be appreciated.
4020 electrician
10-27-2013 18:18:50
 Re: Gleaner F fan and sieve settings in reply to 4020 electrician, 10-27-2013 17:49:19
I' have been running fan wide open. Opening the cylinder up is an easy task but I have been playing with that also. I guess I will take it to 3/8 - 1/2 inch . Should a guy close top sieve or does that effect my air flow to much?
JMS/.MN
10-27-2013 19:06:40
 Re: Gleaner F fan and sieve settings in reply to 4020 electrician, 10-27-2013 18:18:50
Try running the fan about 2/3 open. Chaffer (top sieve) cannot be closed- air should be going through to float trash. Try about 5/8 inch, go to 3/4 inch if needed.
bob 7337
10-27-2013 18:09:15
If you getting alot of splits open the cylinder up a little bit. 1/8 inch should help. as to check where you loosing beans at cutterbar is look under the combine. You also need to let the fan have some air to float the hulls orer the screen
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: 4386 or 4586 IH [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
