Company Logo Shop Now
12v Convert of AC WC
48C-MAN
10-18-2013 08:11:42
I have a 6v pos ground WC backwards loader that I am switching to 12v pos ground. Other than the coil, alt., batt. and light bulbs this tractor has an ignition switch with a starter solenoid. My question is do I need to rewire anything with the switch and do I need a different solenoid?
steve(ill)
10-18-2013 19:21:07
 Re: 12v Convert of AC WC in reply to 48C-MAN, 10-18-2013 08:11:42
your o.k.... but check the alternator. 99% are negative ground.
http://i436.photobucket.com/albums/qq86/steve-ill/alternator-coilWireing-1.jpg
steve(ill)
10-18-2013 19:26:13
 Re: 12v Convert of AC WC in reply to steve(ill), 10-18-2013 19:21:07
third party image
soundguy
10-18-2013 17:31:06
so.. you really went to the expense for a positive ground alternator?
old
10-18-2013 15:07:01
Forgot the say if your going with an alternator you have to switch the ground from + to - or your new alternator will not last a split second
steve_in_mo
10-18-2013 13:29:49
IF you haven't already found it, there's a pretty good set of instructions and a wiring diagram for converting a Farmall M. The WC would have a virtually identical electrical system.
David G
10-18-2013 11:17:49
Better make that 12V Negative ground with the alternator.
old
10-18-2013 08:17:47
No you do not have to do any thing else. Shoot you can keep that coil if you add a ballast resister like the O'Reilly's VR-1
Latest Ad: Looking for a gearbox casing that mounts to a Clinton Machine Company motor Model B764COC Serial# 2070576 part# 3801-C. It powered a Bolen 2 wheel walk behind tractor late 1940s model. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
