hydraulic pump on CA
OldMoIron
I have a pump that has come off a 53 CA. The gasket was leaking so I removed it and the cylinders. I have a three point adapter and wanting to put mower, plow, etc. Can the pump be checked out before re-install, cylinders be rebuilt?
Put the pump back on, and see if you can find someone with a flow meter and guage set-up. IIRR, 3000PSI and 4-5 GPM is the specs.
