Company Logo Shop Now
ALLIS CHALMERS LOSING POWER
NORMAND
09-16-2013 09:33:53
I HAVE A 1951 ALLIS CHALMERS WITH A BELLY MOWER ON IT. IT WAS RUNNING OK UNTIL I BROKE MY MOWER BELT. AFTER REPLACING THE BELT I DETERMINED THE OLD ONE HAD BEEN SLIPPING SO I DIDN"T REALIZE I HAD A PROBLEM. AFTER MOWING FOR ABOUT 5 MINUTES IT WILL START TO DIE AND AS SOON AS I CLUTCH IT IT IS OK. FROM THAT POINT ON I CANT ENGAGE THE MOWER DECK WITHOUT KILLING IT. IT WILL RUN BUT NOT WITH THE MOWER ON. I HAVE REPLACED THE POINTS, COIL, CLEANED THE CARBURETOR 3 TIMES, HAD AN EXHAUST LEAK SO I CHANGED THE EXHAUST/INTAKE GASKET AND THE MUFFLER HAD A LEAK AS WELL AND CHANGED IT. IT SEEMS TO BE STARVING FOR FUEL. HELP
old
09-16-2013 14:02:11
 Re: ALLIS CHALMERS LOSING POWER in reply to NORMAND, 09-16-2013 09:33:53
STOP throwing parts at it trouble shoot then parts or you can/will cause more problems. #1 check that the blades spin freely with out the belt on.
#2 check any and all idlers and make sure they spin freely
#3 make sure with the belt off the PTO spins freely
As others have said good chance you have a mower problem not a tractor problem
Dick L
09-16-2013 11:47:23
About the same as the one below.
johnpop1
09-16-2013 09:41:12
Are you sure that the spindle isn't starting to seize on the deck?
NORMAND
09-16-2013 09:36:28
I FORGOT TO PUT ON MY POST THAT I PUT A CARB KIT IN THE CARBURETOR.
Latest Ad: Heat houser for a john deere 620 [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
