Company Logo Shop Now
WD45 Rear Wheel Removal
Dan Nickels
08-29-2013 07:12:00
I have a flat rear tire on WD45..Rim is shot, so to repair tire I need to replace rim..Cant get it off !?!? Tried to loosen ecentric cam bolts (manual says this is first step) they are frozen solid after 60 years and I fear I will break them...Is there a better way, or do I keep using PB blaster and pray???
Ralphwd45
08-29-2013 20:50:18
 Re: WD45 Rear Wheel Removal in reply to Dan Nickels, 08-29-2013 07:12:00
I use a hot wrench! turn the nuts cherry red, then quench with cold water, usually turn off with little effort.
Brian Jasper co. Ia
08-29-2013 20:22:46
Unbolt the wheel from the hub on the tractor before you try to remove the rim from the center. once all the adjuster bolts are out, lean the wheel up against a tree, fence post, wall, etc and one or two good whacks with a sledge hammer will knock the center out.
Dan Nickels
08-29-2013 12:22:38
Thank you for the responses...This sounds like a better plan than fighting with the adjuster assemblies...(and those nuts appear to be easier to work on)..Thanks...Dan
J. Everett
08-29-2013 10:35:41
I might add, once the center rim is free the adjuster locks will fall off, (do not loose the u shaped spacer on each one), you can then throw them in a bucket of solvent for a week or how ever long it takes to free them up. Take them out every few days and work them over, may take some serious soaking but they will come loose.
Brian G. NY
08-29-2013 07:26:12
Remove the bolts holding the adjuster assemblies to the wheel center. The wheel center will then come off the outer rim and you will be in a better position to work on freeing up the cam bolts.
Latest Ad: 77O GAS ENGINE WITH 1550 OVER SIZE KIT, LOW HOURS, COMPLETE SET UP AND EXTRAS. CALL FOR DETAILS OR PICTURES. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
