Company Logo (800) 853-2651 Shop Now
Need help identifying some old AC parts...
Will Herring
07-24-2013 17:34:47
I got a "bucket of parts", as it were, and I think most of them are off of cultivators, a pull type combine, or mounted corn picker. Any help would be appreciated.
First picture, I think is a blower of some kind for a combine?
third party image
Second picture I have no idea.
third party image
Third picture I recognize maybe a generator belt tensioner for a WD? No idea about the rest of the parts though.
third party image
Fourth picture I have no idea.
third party image
Fifth picture I think I see a seat back but no idea on anything else.
third party image
Sixth picture I see some sort of add-on linkage for the PTO... For some implement? Not sure if that is a clutch plate or what, or if it is even off a tractor. The other seems like some sort of shield or guard of some type.
third party image
Seventh (and final) picture looks like a draw bar. It doesn't have the rounded end on it, so I figure it must be a... WC draw bar?
third party image
JimIA
07-29-2013 07:40:49
 Re: Need help identifying some old AC parts... in reply to Will Herring, 07-24-2013 17:34:47
In the 3rd and 5th pictures there is a C shape bracket, those are to hold the elevators on corn pickers. Pretty sure the slip clutch is for a mounted picker.
Jim
Jerry Coulter
07-27-2013 16:50:56
#1 Hart Carter Scour Kleen attachment.
#2 Canister oil filter.
#3 Generator belt adjust bracket. 3 parts with matching holes to mount header on All-Crop harvester, piece on left appears to be ear broken off the header. WC power lift link. Perhaps an elevator bracket for a corn picker. Perhaps a slide shoe for a sickle mower. Landside heel.
#5 WC seat back. Landside heel. If the flat piece underneath has 3 holes, the center hole might connect to the power lift link.
#6 PTO spring tension slip clutch and U-joint for All-Crop harvester. WD muffler bracket. Engine flywheel.
#7 WC drawbar, I have one NOS like it.
Will Herring
07-28-2013 13:45:20
 Re: Need help identifying some old AC parts... in reply to Jerry Coulter, 07-27-2013 16:50:56
Thank you very, very much sir! :D
BIG RUH
07-24-2013 20:49:12
Pto shaft looks like its for an AC pull type combine. Draw bar should have a second pice
Will Herring
07-24-2013 21:10:05
 Re: Need help identifying some old AC parts... in reply to BIG RUH, 07-24-2013 20:49:12
Any other plow parts in the stuff other than the heel?
Yeah draw bar is definitely only half there (and seems a bit small for a WD -- must be a WC or other?). And good to know the PTO shaft had to be for a combine or corn picker (that is a heck of a spring on that).
Will Herring
07-24-2013 20:38:11
Wonder why the heel isn't actually on the plow... Interesting.
Also, wonder what the drawbar parts are from. Hmmm.
Butch(OH)
07-24-2013 19:27:42
The tear drop shaped cast iron part is the heal for a moldboard plow. Fits most if not all plows that have a part like that on the bottom of the rear landside. The secind picture is an engine oil filter. Allis used similar filters on Us and UCs some model As and even the early WCs and the power unit engines derived from those models.
JMS/.MN
07-24-2013 19:24:53
PTO piece looks like the stub shaft from a mounted corn picker. Along with the scour-kleen you have several drawbar parts.
wd9garymn
07-24-2013 18:14:58
first pic. is a scour-clean for final cleaning of grain. usually mounted on top of the grain tank-- used on many older combines. larger middle area has a screen interchangable with different size holes for different crops.we had 2 moline and 1 ihc combine with them.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: want to buy open station platform and fenders for 4430 john deere, needs to be in good condition . [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
