Company Logo Shop Now
WD45 loader
Ed Raye
07-22-2013 09:32:22
A few months ago Justin SE Iowa posted some pictures of hydraulics added to a WD45 to tilt the bucket. I would like to do the same to my WD45. Unfortunately I couldn't reply to the original post. I would like to know what cylinders and control valve you used to make yours work.
Ted J
07-28-2013 06:52:04
 Re: WD45 loader in reply to Ed Raye, 07-22-2013 09:32:22
Hi Justin, can you email me with some more (better) pictures? And see if you can find where you got the three way?
Thanks, Ted
Justin SE IOWA
07-24-2013 19:12:13
I bought 3000psi cylinders from Northern Tool. I bought a 3 spool valve from another company but don't remember where! I plumbed the "in" on the valve from the lines that went to the rear lift cylinders. Tee'd them into one line. Then the "out" of the valve to the dipstick for the hydraulic fill. I drilled and taped into the side of it with 3/8 npt. Then the first valve went to the lift, second went to the dump bucket, and the third to the rear lift arms. For this all to work the hydraulic lever on the steering column has to be up to "turn" the pump on. Its not as nice as a live system but it works. I can take specific pictures of something if you want. Any more questions please ask.
third party image
third party image
Ed Raye
07-25-2013 08:29:17
 Re: WD45 loader in reply to Justin SE IOWA, 07-24-2013 19:12:13
Thanks Justin. What is the bore and stroke of the cylinders to dump the bucket?
Big orange
07-23-2013 15:57:00
AC made a front pump for the Allis loaders, welded a plate to the front pulley to run the pump, had it's own control box, and used hi pressure cylinders.
Ed Raye
07-23-2013 13:14:44
If it is possible I would like to retain the factory hydraulic system.
JMS/.MN
07-22-2013 22:08:40
That depends on your hyd source. If it"s the original AC system, you need high pressure, low volume cyl. If an add-on, usually low pressure, high volume, using an auxiliary hyd pump and reservoir and valves.
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
