Company Logo Shop Now
D-17 change to negative groundelectronic ignition
larryg9
06-25-2013 08:58:45
do I just change the battery cables or does something else need to be done.
John T
06-25-2013 13:58:26
 Re: D-17 change to negative groundelectronic ignition in reply to larryg9, 06-25-2013 08:58:45
Heres what you have to do:
YES reverse batt cables well duhhhhhhhh
YES swap ammeter leads or it would read bass ackwards
YES swap coil leads if its a coil distributor ignition
YES POLARIZE the genny BEFORE you start it
YES your VR has to be suitable for use at Neg ground
YES be sure new elec switch is for neg ground
orrrrrrrrrrrr how about NOT all that work n hassle n just buy a Pos grnd elec switch????
Your tractor your money your choice, we report now you decide
John T
old
06-25-2013 10:20:20
Fill in the blanks. Why do you want to switch from + ground to - ground?? You changing to an alternator or what?? If you not changing to an alternator then there is no rime or reason to switch. So give us more info so we can help you help your self
Kip-Utah
06-25-2013 09:21:32
Ammmeter not ampmeter and Butch is correct except with the new polarity the ammeter will show discharge when charging and vice-versa unless you reverse the wires.
Butch(OH)
06-25-2013 09:11:08
Had to scracth my head a minute about what Kip said about the ammeter but I dont think you need to change it as it only knows the direction of flow. You need to re-polorize the generator and depending on how old the regulator is you might have to change it as the older ones were polarity specific, the new ones are not. You also need to reverse the low tension wiring on the coil as he said
Kip-Utah
06-25-2013 09:05:23
You also need to reverse the connections on the coil and ampmeter. If running a generator you need to reflash it and change the polarity.
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
