WD rear axle bearing Replacement?
Has anyone replaced a outer rear axle bearing in a WD? I have the snap ring off the bull gear slid all the way over and can not get the axle out. I tried to separate the bull gear housing from the axle tube and can not get it off either. How do you get to the bearings?
Thanks!
Do you still need info? I have an Allis Chalmers service manual that would cover that and could scan pages to your E-mail(need Address). I think I remember the drive shafts come out of the Differential when you take the final drive off. One summer about 45 years ago my Dad took off to cultivate and tractor would only back up and not go forward. We tore into it in the front yard and before we found the bad bearing somewhere between the transmission and rear end we had all the final drives tore apart and the differential out and replace everything that was bad. I still have that tractor and it needs a bearing again but next time I'll start at the front to get to it.
From what I remember about axles the snap rings are the hard part. Allis used the stiffest snap rings in the worst places. Cleddy
I will try to scan this to you. Hope it helps.I'm not sure how to do it so hopefully you can read the info.
cleddy
