Company Logo (800) 853-2651 Shop Now
Help wanted with Vintage FM Coils
mdtractormechanic
06-06-2013 20:09:31
I have several Fairbanks Morse coils that came out of type fm and fmk magnetos. They are made of the cloth and varnish construction. They have been tested with a Merc-o-tronic 98 and meet specs.
My question is this. The exterior covers are deteriorating. Should I revarnish the coils or use a rubberized covering material instead, or maybe use something else?
Thanks, Joe
Earl-IL
06-09-2013 12:38:01
 Re: Help wanted with Vintage FM Coils in reply to mdtractormechanic, 06-06-2013 20:09:31
I do magneto repair. I found most of the old wrapped FM coils will fail after they get warmed up. I use a old Eisemann Tester and let it run about 20 min at 1.7-2.0 amp. and then I take a heat gun and warm the coil up real good about the same temp as a mag would be on a AC tractor or Wisconsin V4. About 50-75 % of them miss fire or quit firing.
mdtractormechanic
06-09-2013 13:31:41
 Re: Help wanted with Vintage FM Coils in reply to Earl-IL, 06-09-2013 12:38:01
I actually heated the old coils in an oven @ 190 deg. for an hour before testing them. 1 of the 4 failed. The other 3 are going to get resealed. Thanks
Earl-IL
06-09-2013 16:15:33
 Re: Help wanted with Vintage FM Coils in reply to mdtractormechanic, 06-09-2013 13:31:41
That is good. That is better odds than I get. The red insulation spray I got from a electric motor shop. Earl
mdtractormechanic
06-08-2013 11:34:00
I think I'll use insulating varnish applied under a vacuum to reseal the interior (bake to dry) then apply liquid tape to the exterior. Thanks for the suggestions.
greygoat
06-08-2013 08:13:18
Thanks..Dalex !
yes, Glyptal, appears to be the correct stuff,
I just "Google'd it, still available,NOT CHEAP !
Dalex
06-07-2013 13:36:01
That stuff gg is talking about is called Glyptal
greygoat
06-07-2013 07:56:43
When I was a Machinist apprentice on C B & Q
railroad, we used a reddish colored varnish to
re-varnish, switch engine main generator windings.
It seemed to be the same stuff that I see on old magneto coils. I don't remember what it was called
but it was made by DuPont. Perhaps a phone call to
a magneto rebuilder/parts supplier, such as
Branson Enterprises (www.bransonenterprises.com)
would get you some information. I scanned their
web site, but saw no special varnish listed.
motorcraftman
06-08-2013 14:54:31
 Re: Help wanted with Vintage FM Coils in reply to greygoat, 06-07-2013 07:56:43
at the Motor manufactturing plant where i retired, Baldor Eklectric the RED Insulating paint, We called it GLYPTOL Also. Larry
Today's Featured Article - Search For Spares - by Anthony West (UK). Following on from the aquisition of the old Fordson F, I was very much in need of spares. As a novice though I didn't appreciate the fact that there were so many Fordson tractors made, that all the other makes seem rare by comparison. As far as I was aware a fordson was a fordson and it was only through trial an ... [Read Article]
Latest Ad: 48 John Deere GW in pieces [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
