In the 60s and 70s Several farms around here used Allis Chalmer snap coupler tractors to plant tobacco. There were green brackets that bolted to each side of the engine to install 2 to 4 55 gallon drums of water for the transplanter. I have been looking for a photo, have not found one. I think I have a photo of 1 55 gallon drum on a Farmall... the AC we used had 2 of these.
The story I was going to post it with... The job no one wanted was to turn the Briggs-Stratton pump off, the spark plug would nip you even using a stick to turn it off. One time I got distracted with a new insect and my father got his shirt wet. (94* outside, I saw no problem with anyone getting wet)
The next round, my job was to fill the tanks. I had to use two pieces of firewood to stand on to get the lids open. Everything went OK with the first. With the second, I leaned up on tiptoe to see how full it was. The wood tipped over, I bumped my head on the barrel and the hose got away from me. It whipped around and drenched my father! We all had a good laugh after the pump was turned off and got back to work.
