190xt gas hydraulic prob ?
Darren Z
New User
Hello I just got another 190xt this one is a gas serial number 6064 after getting it home I got the motor running changed all fluids stated it but to get it to steer have to rev engine way up high side of director you can slip if u push brakes hard does the pump effect all this ?
This tractor also has small axles did they do updates to the gas xt tractors my other is a 190xt diesel serial number 1750 and it has big axles just a ?
There were 3 series of the 190XT. ReaR ENDS WERE THE MAIN PROBLEM. fACTORY HAD UPDATES, some dealers did them, some not.....then you had to pay for them. Locally, FRIH, if you were a dealer bud, it got fixed. Some got forgotten.
Early 190's also had the wrong dipstick in the motor, dad bought 1 at a sale. They didn't have enough oil in the motor, cost dad a motor. They were supposed to get replaced by the dealer, as you said some got forgotten.
Yes everything works on hyd pressure and dont slip the PD much it will be ruined,, theres a valve that needs to be cleaned and then the pressure checked, - a gas 190 will be fine with the small axles and rear end, they never touched them, you may go to Unoffical Allis. Com alot of good answers over there
Thanks for the info . This is a great site for more input and help than what you can get trying to call around
