Procedure for stopping the PTO on a WD?
Will Herring
I know the procedure for starting the PTO is:
1. Be STOPPED
2. Put transmission in gear
3. Engage PTO
4. Slowly release clutch
But what is the procedure for stopping the PTO?
I usually take my heal and kick it out of gear a little bit before I aim to stop and the drag will shut it down pretty quick. If it is free running slow the engine down as far as possible, then kick it out of gear. STAY in the seat until it STOPS.
(quoted from post at 21:31:21 05/13/13) I usually take my heal and kick it out of gear a little bit before I aim to stop and the drag will shut it down pretty quick. If it is free running slow the engine down as far as possible, then kick it out of gear. STAY in the seat until it STOPS.
So... Can you shut the PTO off while the tractor is in gear and moving, then? Or is it you can shift it out of gear while the tractor has the PTO engaged and then later disengage the PTO? No clutch required to disengage?
Yes, you can disengage the PTO without stopping, but
I prefer to depress the clutch while doing it, so
there is no wear on the sliding gear. No need to
disengage the transmission unless you also want to
stop moving.
I would add to the engaging procedure.I would start the PTO turning with the hand clutch disengaged and when up to speed , start forward motion with the hand clutch.
What I have always done is stop the tractor with the with the hand clutch then push in the foot clutch then take the PTO out of gear. Ya you can pop it out on the move but that can cause a problem if it does not go out all the way and I have seen gears with chipped teeth or even a broken PTO housing because it does not go out of gear all the way then jams a gear tooth. Ya not likely to happen but can
(quoted from post at 11:14:03 05/14/13) What I have always done is stop the tractor with the with the hand clutch then push in the foot clutch then take the PTO out of gear. Ya you can pop it out on the move but that can cause a problem if it does not go out all the way and I have seen gears with chipped teeth or even a broken PTO housing because it does not go out of gear all the way then jams a gear tooth. Ya not likely to happen but can
Once you take the PTO out of gear, can you re-engage the foot and hand clutches, or do you need to wait for the PTO to stop spinning to avoid this issue?
Once you have the PTO out of gear you can go on about your business let up on the foot clutch an engage the hand clutch. Only time I might wait a bit is if I have a brush hog on and that is just so as not to cut up the air etc. Never have likes to have the blades spinning when going some place
(quoted from post at 12:07:18 05/15/13) Once you have the PTO out of gear you can go on about your business let up on the foot clutch an engage the hand clutch. Only time I might wait a bit is if I have a brush hog on and that is just so as not to cut up the air etc. Never have likes to have the blades spinning when going some place
Good to know. I mostly use it for mowing.
Thanks. :)
To STOP the PTO and the attached equipment, you simply push IN on the Foot clutch and STAND on the Brakes..
Just that simple...
It all depends on just how quickly you need to Stop..and NO, I do NOT recommend any "Over-running Clutch"...they take away that control, to be able to STOP the moving equipment in an Emergency.
Ron..
