Company Logo (800) 853-2651 Shop Now
big ten
donald cramer
05-06-2013 06:13:01
I have a big ten and am having trouble figuring out how to hook up the deck belt and chain. It is hydraulic lift and seems to be all complete. The pulley on the deck is horizontal and the one on the tractor is vertical. By looking at it it doesn't seem as it will work. Does anyone know what size the belt is also? A thousand thank yous
CJinMI
05-06-2013 10:34:14
 Re: big ten in reply to donald cramer, 05-06-2013 06:13:01
Go to simpletractors.com. AC & Simplicity (also built for private label). Site is full of info. And yes the belt twists, if twisted wrong, the blades run backwards. You should be able to see where the belt rubbed on the deck suspension--a round tube. I don"t remember the size, would have to dig out my old manuals, sorry. I can tell you tho' that the 2 belts (1 clutch, 1 deck) need to match total length. If 1 is not right it affects the other. The idler swings. I've used 'A' belts, but if you use a oem and a 'A' you'll fight keeping the clutch adjusted. Had the best luck with either 2 'A' or two oem. I"ll try to find the 'A' #'s I wrote down. Hope I didn"t just confuse you, being long winded.
don kramer
05-07-2013 05:20:03
 Re: big ten in reply to CJinMI, 05-06-2013 10:34:14
Could you give me a call? 814-929-9841 I changed the spelling of my name because I couldn't remember my password
CJinMI
05-18-2013 12:09:21
 Re: big ten in reply to don kramer, 05-07-2013 05:20:03
Tried to call, no luck. callfinally connectted, but my # is blocked (co phone) and won't go thru.
Haven't found my notes, which deck?.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
