CA 3 pt mounting pins
RalphWD45
I have a 52 Allis CA, that has two 1" pins under the axle housings, which aparently are pressed in to cast tabs on the axle housings. The cylinders that I want to use have 3/4 " pin holes, and can;t be reamed out to 1"(not enough material). I have 2 questions , one is do they make replacement pins that are 3/4" on one end, and 1" on the other?, and and if they are available, then how do I press the old pins out of the axle housings?
