Can an AC B (1939) be equipped with a front snow plow?
If you can find a loader for it you are 90% there. Otherwise you are in for something of a fabrication job. You'll most likely end up adding a PTO driven hydraulic system as the original will be very slow and won't have enough oil capacity to lift much.
If it has hyds yes it can be done. Many years ago some one here posted pictures of a snow plow lift that he had on his B and he sent me pictures of it and I built one for my C and improved on its design.
One of mine has a hydraulic plow run by a GM power steering pump and a Farmall valve.
The other has what appears to be a factory, manual lift front blade.
