Company Logo (800) 853-2651 Shop Now
1939 b won't start, low comp.
Eriklane
04-07-2013 15:04:46
60-62psi cold on all cyls. Tractor was pull started last week and past summer, does run. Gas flowing, but couldn't get a spark.
Do these have cylinder sleeves? Cost?
Sounds like it may need a magneto-cost?
Eriklane
04-08-2013 11:13:43
 Re: 1939 b won't start, low comp. in reply to Eriklane, 04-07-2013 15:04:46
This is a B obviously...
Kip-Utah
04-08-2013 10:44:50
C was sold as a standard tricycle,single front wheel, and adjustable wide front. We have one of each. In our part of the world wide front Cs are more common than the the tricycles. Kip
Momac
04-08-2013 04:18:08
C's were available with wide front ends as well as single wheel front ends. The rear wheels were 5 bolt dished where as the one pictured is a B the standard cast rear wheels. The 5 bolt wheels were a option on the B with a adjustable width front end also. Mike
Paul from MI
04-07-2013 18:56:27
60 psi is a bit low, unless it has distillate pistons in it. Even so, it should start ok with that much compression. I would start looking at the mag and carburetor as the source of your problem. Hot spark and gas make a huge difference in starting. My old 2 cylinder Deeres start in very cold weather on about that same compression. As Old says, the low compression may very well be due to stuck rings, especially if the tractor hasn't been run much or worked enough to get up to temperature for a while. Maybe just a good workout will help a bit.
Eriklane
04-07-2013 17:37:25
It's not mine-I'm considering it. It's a '39, crank start, nice tin and paint is good, needs a rub out, tires good, and comes with sickle bar, he wants $1000 firm. I want to get rid of my 8N which is more $ than I really need nowdays. I just need a mower, really, and can pull a cultipacker if I want.
I did my sleeves on the 8N, but, it was lot of work. B's are simpler. But, that price-if it were $750, I'd take it, I think...
What ya think? third party image [img]
This post was edited by Eriklane at 17:42:04 04/07/13.
dej(Jed)
04-08-2013 09:09:58
 Re: 1939 b won't start, low comp. in reply to Eriklane, 04-07-2013 17:37:25
$750 is plenty for a B...
old
04-07-2013 21:01:58
That is not a C o if it is it has a B wide front on it. The C only came with a trike front and the B with a wide front. Many years ago I had a B that was hand crank and it was the very first tractor I ever rebuilt the engine on. The sleeves are wet sleeves and can be doe with out mach work. I did all the sleeve seals on the C I have and it did not take a lot of work or $$
Eriklane
04-07-2013 15:45:31
I suspect it may need points or something minor, or coil. More concerned about the sleeves. Can I do it by removing the pan and head and hood, doing it with the rest of the tractor intact?
WHat's the cost of sleeves?
old
04-07-2013 15:59:15
 Re: 1939 b won't start, low comp. in reply to Eriklane, 04-07-2013 15:45:31
Those number are low but could well be as simple as sticking rings. I would fill the cylinder with ATF and let it sit a couple days. Also as for the mag they are not all that hard to work on if you have the manual which is also easy to get. To get a manual just send me an e-mail and tell me which mag it has. There where 2 common ones used by AC and I have both manuals on this computer
Ted in NE-OH
04-07-2013 15:13:00
60 psi is low. Yes they have sleeves.Rebuilt mags go about $235
Today's Featured Article - Search For Spares - by Anthony West (UK). Following on from the aquisition of the old Fordson F, I was very much in need of spares. As a novice though I didn't appreciate the fact that there were so many Fordson tractors made, that all the other makes seem rare by comparison. As far as I was aware a fordson was a fordson and it was only through trial an ... [Read Article]
Latest Ad: 48 John Deere GW in pieces [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
