Company Logo Shop Now
WD instrument panel
thebigyellowtruck
04-01-2013 05:44:00
Can someone please post a few pictures of a WD instrument panel. I am rewiring my WD and noticed that my panel has 4 holes. 1 for ammeter, mag kill switch and lights. I cant figure out why there would be another hole smaller than the light switch hole. Thanks for the help in advance.
This post was edited by thebigyellowtruck at 17:49:44 04/01/13.
thebigyellowtruck
04-02-2013 08:59:08
 Re: WD instrument panel in reply to thebigyellowtruck, 04-01-2013 05:44:00
that answers everything. thanks guys.
stu (ON)
04-02-2013 05:52:10
third party image[/img]
The holes are for Switch Rod, Switch Screw, Magneto Ground & Ammeter
thebigyellowtruck
04-01-2013 20:10:28
Thanks guys. Since i bought some headlights off of Old and I'm converting this tractor to 12volt I'm fixing some damaged tin work like this panel and battery box. I just want it to look correct for the most part except for the alternator of course.
old
04-01-2013 21:48:41
 Re: WD instrument panel in reply to thebigyellowtruck, 04-01-2013 20:10:28
If I remember I guess I should look at my parts WC and Parts WD and my WD45 and see how each one looks then maybe take a picture
thebigyellowtruck
04-01-2013 17:45:53
thebigyellowtruck said: (quoted from post at 22:44:00 04/01/13) Can someone please post a few pictures of a WD instrument panel. I am rewiring my WD and noticed that my panel has 4 holes. 1 for ammeter, mag kill switch and lights. I cant figure out why there would be another hole the same size as the light switch hole. Thanks for the help in advance.
Here is my panal. Is this how the rest are? third party image
This post was edited by thebigyellowtruck at 17:48:11 04/01/13.
Brian G. NY
04-02-2013 08:06:39
 Re: WD instrument panel in reply to thebigyellowtruck, 04-01-2013 17:45:53
third party image
I think this is how the WD-45 panel differs from the WD panel.
Brian G. NY
04-02-2013 07:27:04
third party image
Picture from WD-45 Manual.
Brian G. NY
04-02-2013 07:39:20
 Re: WD instrument panel in reply to Brian G. NY, 04-02-2013 07:27:04
third party image
This picture is also from my WD-45 Manual but this is obviously a WD as it has a straight shifter and a magneto switch.
Is the hole you are speaking of like the one below the light switch in this picture?
I guess that only adds more mystery to the question!! LOL
thebigyellowtruck
04-02-2013 08:05:24
 Re: WD instrument panel in reply to Brian G. NY, 04-02-2013 07:39:20
In the picture i posted i dont know what goes in the smallest hole. The 2 roughly 1/2" holes and the 2" amp meter hole i know what goes there.
Brian G. NY
04-02-2013 08:09:22
 Re: WD instrument panel in reply to thebigyellowtruck, 04-02-2013 08:05:24
What TED says; the screw that holds the light switch.
If you look real close, you can see those screws in the pics I posted from the manual.
Brian G. NY
04-02-2013 08:17:58
 Re: WD instrument panel in reply to Brian G. NY, 04-02-2013 08:09:22
third party image
Here is a "tighter" view of the picture Stu posted.
The screw is actually shown here.
Ted in NE-OH
04-01-2013 18:37:30
That is a normal WD instrument panel. The small hole is for a nut and bolt to hold the original light/charge switch.
Ted in NE-OH
04-01-2013 09:02:24
The WD 45 that uses the same instrument panel has a hole for a key switch.
Brian G. NY
04-02-2013 07:51:12
 Re: WD instrument panel in reply to Ted in NE-OH, 04-01-2013 09:02:24
I believe the later WDs (with battery ignition) also have the key switch like the WD-45s.
Also......the light switch is moved to the right and the magneto kill switch was eliminated on these newer tractors.
JMS/.MN
04-01-2013 21:24:30
But that hole is on the underside of the panel.
old
04-01-2013 07:43:33
Every one I have seen has that extra hole with a plug in it. Guess they did that so a person could add a switch if they wanted to with out having to drill a hole
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
