Company Logo (800) 853-2651 Shop Now
4 -16 plow on a 200 in fescue sod??? Has coulters
LeakyBoot
03-19-2013 06:44:32
Will the 200 handle this ok?
rufus80
03-19-2013 17:43:34
 Re: 4 -16 plow on a 200 in fescue sod??? Has coulters in reply to LeakyBoot, 03-19-2013 06:44:32
Father in law ran his 200 with a MF 5-16 onland hitch plow with no problems. But he did have duals and lots of weight added.
1206SWMO
03-19-2013 16:52:23
Our 200 AC pulled a 5x16 IH plow....It did weigh 12,000 lbs..
LeakyBoot
03-19-2013 06:45:37
Might add----no wheel weights and no fluid in tires.
LonnAC7050
03-19-2013 21:52:26
 Re: 4 -16 plow on a 200 in fescue sod??? Has coulters in reply to LeakyBoot, 03-19-2013 06:45:37
Better add some weight or you might have differential problems due to excessive wheel spin.
massey 333
03-19-2013 09:02:21
Tractor is fine or very good,however you will need some more weight to be good to go.Unless you are running in sand.
tomstractorsandtoys1
03-19-2013 07:04:21
My Grandfather bought a new 190XT with a six bottom 16" AC plow, so you should be fine with a 4 bottom.We pull 4 bottom with a 4010 Deere just fine.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
