D17 Wheel Tread
Cam50
My plow manual, (70 series), says using 3-14's the rear tread should be 63". Where is this measured? Inside of wheel? Center? Outside? Seems to me I should be more focused on tractor center to inside of furrow wheel. Educate me guys! Thanks
Without going to the Operator manual showing the various settings......IIRC, tread is measured center to center of the tires........and normally that is meant that each wheel is an equal distance from the center of the tractor. That tread measurement does not vary with oversize, undersize, or standard tires. It's also illustrated that way in Gleaner combine literature- irregardless of tire options.
