Company Logo (800) 853-2651 Shop Now
allis wd wireing diagram
Duane4248
02-27-2013 13:07:39
does any one have a wireing diagram to change allis wd 6 volt to 12 volt alternator thank you
Ted J
02-28-2013 04:58:25
 Re: allis wd wireing diagram in reply to Duane4248, 02-27-2013 13:07:39
Here is his page:
http://dueyschutter.freeservers.com/photo3.html
old
02-27-2013 15:39:14
What diagram. It is a very simple 3 wire set up if you use a Delco 10si and one of the 3 wires is less then 4 inches long. I can explain it but do not have the diagram but then I can pretty much do it in my sleep. You have a 2 wire plug with #1 and #2 on it. The #2 goes to the charging stud as in the big one on the alternator. The #1 wire goes to the ignition as in to the coil works well with a Radio shack diode 276-1661 cost if $3 for a 4 pack. The big charging stud you use a #10 wire to the amp gauge switch the 2 wires and hook the charging wire to the one you would have switch from the gen
mdm1
02-27-2013 14:54:09
Do a search for Duey Schutter. Should have all the info you need.
Today's Featured Article - Search For Spares - by Anthony West (UK). Following on from the aquisition of the old Fordson F, I was very much in need of spares. As a novice though I didn't appreciate the fact that there were so many Fordson tractors made, that all the other makes seem rare by comparison. As far as I was aware a fordson was a fordson and it was only through trial an ... [Read Article]
Latest Ad: 48 John Deere GW in pieces [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
