Company Logo (800) 853-2651 Shop Now
Allis Chalmers B- Headlight help
kenny/md
02-16-2013 10:35:21
I have a 1949 B, that Im putting headlights on. Is there a angle bracket that you mount to the grill shell, then bolt the headlight to that, or does the stud of the light go through the grill shell? Im just wondering what was factory. Thanks
steve(ill)
02-16-2013 19:33:11
 Re: Allis Chalmers B- Headlight help in reply to kenny/md, 02-16-2013 10:35:21
If you use aftermarket lights with a tin bracket on them, i have taken a 1/2 inch bolt about 1 or 1-1/2 inch long and drilled a 3/16 hole thru it.
Paul from MI
02-16-2013 18:35:20
Headlight has a hollow stud that is held in the hood & radiator shell with a jam nut & washer on each side. Wire from the lights and the light switch are connected on an insulated threaded stud in the fan shroud on the left side of the radiator, Hope this helps.
Paul
Bob Bancroft
02-16-2013 11:23:51
If I remember correctly that's a 1/2" NC thread in the radiator. The stud in the lamp is hollow so the wire can run through it. They could be hard to find, unless you buy OEM, which last I knew was MEGA $$$$$$$$$$$ !
old
02-16-2013 10:39:21
All the head lights I have messed with on the B and C the light had a bolt on it that then screwed into the grill area
CTucker
02-18-2013 18:06:57
 Re: Allis Chalmers B- Headlight help in reply to old, 02-16-2013 10:39:21
The light has a hollow threaded stud. It does not screw into the rad shroud as there is no place to tap threads. There are jam nuts on both sides of the rad shroud.
old
02-18-2013 18:55:21
 Re: Allis Chalmers B- Headlight help in reply to CTucker, 02-18-2013 18:06:57
Guess you got one that was messed up. ALL the Cs and Bs I have had the bolt or stud just screwed into the grill area
Bob Bancroft
02-18-2013 18:12:37
Maybe on something of yours. But originally there was a little threaded piece of metal spot welded to the inside of the radiator flange.
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
